Home > Wheels & Tyres > 255/55R20 on a 2008 SC L322?
d00d
2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Found a nice set of barely used 255/55/R20 at a good price, but my 20in L322 (2008 SC) has 255/50R20 mounted.
Found a few folks who say they might rub, but nobody who's actually tried them.
Anybody have real-world experience with this size? Rolling Eyes 2008 SC L322
2001 P38, Epsom Green, fully restored SOLD
Post #424983 27th Jan 2017 4:02am
rar110
I have 265/60/18s which are bigger, and they don't rub. 275/55/20 will unless lifted I believe. ______________________________
Post #424986 27th Jan 2017 5:31am
d00d
By my calculations:
255/50/20 = 30.039" diameter
255/55/20 = 31.043" diameter
265/60/18 = 30.520" diameter
275/55/20 = 31.909" diameter
So it looks like your 18's are about 0.5" larger than what I've got but still 0.4" less than what I'm looking at.
And what I'm looking at is only 0.5" smaller than one which is apparently known to rub.
I think that helps me decide better not to risk it, thanks! Mr. Green 2008 SC L322
Post #424989 27th Jan 2017 5:49am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
255/55/20 rub lol never heard such bull, loads of us use them and a far better ride and loads of room still Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #425012 27th Jan 2017 9:02am
Rob99
Re: 255/55R20 on a 2008 SC L322?
Rolling with laughter Rolling with laughter
Thank Censored you found this site, where you will at least get very good and correct advice Thumbs Up
If your standard 255/50R20's aren't showing at least a couple of inches clearance in the wheel arch then you probably have an issue with your air suspension Whistle 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #425061 27th Jan 2017 2:35pm
d00d
Suspension works fine, room around the arch looks plentiful, I'd just been worried about bits touching on the inside of the well when the wheels were turned hard, but sounds like that's not a problem, woohoo! Thanks all! Thumbs Up 2008 SC L322
Post #425077 27th Jan 2017 5:05pm
Quite a few of the folks on here have started running the as they are an increasingly common size from the l405. Not heard any issues as yet. There is nothing that can't be fixed with a hammer😜😜
Post #425151 28th Jan 2017 8:22am
rangie47
buy them ,fit them ,no problems Thumbs Up 2007 tdv8 se ,stornaway grey
Post #425673 30th Jan 2017 7:13pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I removed my 255/50/20s for 255/55/20s the new tyres were from an L405.
It rides perfectly. If I remember correctly the speedo is now completely synced with GPS speed.
The extra tyre profile is an additional 5% of 255mm. They won't rub! Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #425697 30th Jan 2017 10:17pm
Sandyt
Sorry to hijack but those that have fitted them do you notice a difference in the handling it is just that I run 19 on 255 55 for winter and compared to summers on 20 255.50 it feels less firm
Interested as my summers have less than 4mm so will change for new tyres in spring
Post #425742 31st Jan 2017 9:41am
d00d
@Sandyt - took awhile but I finally got around to getting them fitted. First thing I noticed was the 2.5cm height difference is definitely noticeable, "riding taller". (Maybe more like 3cm for how bald the old ones were!)
Ride-wise, for the most part it just sounds and feels like the difference between somebody drumming on a table covered in one layer of felt vs 1.5 layers, i.e. noticeable, but not exciting.
However, there's been a nasty pot-hole developing on my drive to work and while I usually miss it traffic conspires once in awhile to run me right across it. With the old 50cm wheels it was quite a bang, (and surely the cause of some new nicks in the rim). With the 55s on though it was still a big thump, but nowhere near as "sharp". HTH, YMMV etc. 2008 SC L322
Post #444745 17th Jul 2017 4:17am
Weegie
What pressures are people running 255.55.20s on? John
GAP iiD BT
Post #445280 21st Jul 2017 3:09pm
d00d
As long as other conditions (weight, distribution, road surface, contact patch) aren't changing, you'll most likely want run exactly the same. 2008 SC L322
Post #445282 21st Jul 2017 3:49pm
Weegie
? same as what 255.50.20s? John
GAP iiD BT
Post #445288 21st Jul 2017 4:56pm
CS
That is what I have been doing, 33 front & 36 rear, Goodyears on 405 style 502 wheels, pleasant comfortable ride. Only Range Rovers since 1988
Post #445295 21st Jul 2017 7:28pm
