Home > Technical (L322) > Front dirver Door locked
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
Hi
From time to time I cant lock the front driver door. Its typical in sub 0 degrees temps. Today I was not bothering holding the door while driving, sow i manualy lock it with the door locking button (center panel). yeah the door lock but now it will not open.
Iw driven the car sow that its warm, but that did not do help getting the door lock to open. Iw tried to open the door using the key, and iw delited fault codes. No good.
Sow whats this all about. Help is needed.
Thx. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #424538 24th Jan 2017 9:07am
Norway
Funny thing. The door is now posible to open. lol'
Just had to give it some time. -03V td6
Post #424555 24th Jan 2017 12:07pm
the door latches/locks do get frozen easily....on my old td6 i took the lock out and greased everywhere and didnt have any problems after...
Post #424556 24th Jan 2017 12:11pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
Wot Stan said. Make sure they are liberally greased with a low temp grease if poss. Also had this when skiing (-18 degrees) and a squirt of light oil into the mechanism and all moving parts solved it. Thumbs Up
Post #424602 24th Jan 2017 5:57pm
Norway
thx,Iam on my way to the shed to find som grease or lock oil. -03V td6
Post #424616 24th Jan 2017 6:57pm
