![]() | Home > Maintenance & Mods (L322) > 4.4 M62 lambda control adaption faults, won't go closed loop |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
I should also say it would appear on the surface to be running absolutely fine. 2003 4.4 Adriatic Blue FF |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
The o2 upstream sensors should be reading between 0v and .8 cycling every second or so on idle when warm. Rears should stay a steady .45 v. A MAF reading would help. Look for approx 22kgs hr on idle with loads off No7 - 2003 V8 Vogue |
Thanks.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I have similar issues but have done the PVC valve and hoses yet. Interested to see how this turns out. |
Here you go. I had a dig around and found these known good MAF values from when I was diagnosing a miss fire..
I'm getting roughly from yesterday's check
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
I'm getting the very same fault - we live in Farnborough, it must be the air!
Dont buy cheap. No7 - 2003 V8 Vogue |
73+ vat off my mate at CAF |
Let me know how you get on, or it is definitely the air.... |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I bought the Bosch MAF from Eurocarparts as if I applied a light throttle up to around 1000-1200 rpm the engine would hunt up and down considerably and with the new MAF it is great.
Thanks for that. That's Exactly what mines doing at the moment..
I cleaned my MAF last year and it made some difference, the MAF may not be the complete cure but you need to know it is working 100% to be able to diagnose any other issues |
New Maf giving essentially the same readings as my old one. Still hunts when you try and hold low revs around 1000rpm.
