![]() | Home > Maintenance & Mods (L322) > 4.4 M62 lambda control adaption faults, won't go closed loop |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I'm not sure if the throttle adaptions have to be relearned, see how it goes after a few runs |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Ideally adaption should be reset after changing any sensors, but the Motronic is a quick learner and should sort it's self out after a few runs No7 - 2003 V8 Vogue |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
Well my new maf gave pretty much the same readings as my old one but I left it on, 200 miles later the lights stayed off so I think problem solved.. thanks for all ideas |
