Home > Technical (L405) > Frozen air intake ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 |
i think the tank is 89 litres on the L405 so you fill up 79 litres and then 10 litres ? |
13th Apr 2019 9:10am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
I'm sure my tank is bigger than that... maybe 90L
13th Apr 2019 5:34pm |
that makes sense... |
13th Apr 2019 8:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
My 10p bet says its not freezing fuel!
13th Apr 2019 8:29pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 |
Wow — an old thread
14th Apr 2019 8:01am |
I know it's an old thread, but I learned something today related to this. Chatting to a guy who does the off road landrover experience at rockingham, he says the intake has a complex valve system designed to divert to alternative air the moment resistance from wading water is detected. In cold temperatures sometimes these valves get stuck and wont open, meaning when you start the engine your running on residual air in the pipes, you then choke the engine, it dies, then the sucked in rubber hoses de-compress after a few minutes and your able to start again, and the same happens....
26th Sep 2019 8:00pm |
http://www.fullfatrr.com/gallery/albums/us...RATION.pdf
26th Sep 2019 8:21pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 |
Cheers Stan, you will have to give me a lesson some day
26th Sep 2019 8:24pm |
Interestingly I think I will blank off my EGR given it's so accessible at the top. After cleaning the MAP sensor the other day I noticed the intake is full of carbon and soot |
27th Sep 2019 4:56am |
