Home > Maintenance & Mods (L322) > Scissor lift for garage/workshop |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Ahh. Thought it would be something like that.
11th Jan 2017 8:46pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Those don't work as well as they should... they tend to run out of lift before the wheels get off the ramp... by experiment it was found to be an advantage to start in high mode and use some large packers... where as a 2 post lift is by far a better option, except you don't have as much storage space for the bits coming off Yesterday I couldn't spell Engineer... Today I are one!
11th Jan 2017 8:47pm |
Yes an air operated jacking beam
11th Jan 2017 8:53pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Lovely setup. John
11th Jan 2017 8:55pm |
Food for thought.
11th Jan 2017 9:46pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
Jealous me? noooo 405 AB exec seats Baltic and Cirrus
12th Jan 2017 8:07pm |
Ginja Member Since: 17 Mar 2016 Location: England Posts: 26 |
I have the green strongman clifton as shown in the first post in my garage - had it since Feb last year. I don't use it very much but its important when I do. It was able to lift my 2005 Dodge Ram which believe it or not is a similar weight to an L322. It comes in a forklift style wooden box which contrary to the video you cannot remove the raised forklift sections from so getting it out of the box was a nightmare. Had to cut the box off while supporting and lowering it from two jacks. You can move it about the place if you are strong and mine at least came with the hydraulic fluid as well, you just need the correct power supply and off you go.
24th Jan 2017 3:56pm |
Reach Member Since: 20 Jan 2017 Location: 'Merica Posts: 4 |
I've got an inexpensive Chinese made 2-post lift designed for low ceilings. I've got 9'3" height in the garage, and these posts come in just over 9', fit without modification. 8000lbs load certified, had no problem lifting the Rover. Mostly I use it for low-and-light sports cars which it can lift high enough for me to sit comfortably under and work on, but with the RR I can get the wheels about 6" off the ground with the garage door open, or 24" off the ground with the door shut.
25th Jan 2017 3:13pm |
Strongman Tools do a 4 Ton 2 post lift that's almost a thousand ponds cheaper than that scissor lift, and is far more useful
25th Jan 2017 11:07pm |
