Home > In Car Electronics (L322) > Changing vogue head unit
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I have a 53 plate vogue and have the nav screen and radio etc but to me it looks old and tired and I would love to update it.
I've read the posts about the android units being installed but I'm happy with the sound and don't want to loose the sub.
So what I'm trying to find out is can I change the head unit to the later 06-09 head unit with very little hassle or am I stuck with what it came with?
Post #421295 5th Jan 2017 5:25pm
They are totally different systems
The '03 is all BMW electronics - then after 06 they went to Ford systems - almost nothing is compatible.
You may have more luck with later BMW hardware - but don't expect easy upgrades.....
Post #421302 5th Jan 2017 5:51pm
You don't have to lose the sub with the Android unit, it has separate outs for a sub which you can use... Thumbs Up Pete
Post #421304 5th Jan 2017 5:53pm
miggit
Whistle If you want to be super fussy about the sound.. (and I thought I was until I discovered that the sub wasn't even connected Shocked ) you an add passive 3 and 2 way crossover networks and run a phono extension lead from the head unit to the boot, where you can add an amp and then wire it to the LR sub... easy as it's all exposed during the installation Thumbs Up
I have an amp, I have run the lead from the head unit, but thats as far as it got as I feel it's not required for my ears Rolling Eyes I haven't even bothered with crossovers... I ran on the logic that it could be easily added in the boot if required, just remember to run the phono when you feed the loom Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #421310 5th Jan 2017 6:29pm
