Home > Technical (L322) > Air Suspension problems on MY2011 FFRR bought last week! |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
Presumably you've got a 3 month warranty on the vehicle - don't all dealers have to do this now ??
14th Jun 2015 1:20pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Sounds like the compressor. The fact the car stays the same height overnight suggests the airbags are fine.
14th Jun 2015 4:45pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I agree with Ian. It sounds like compressor. I had this along with forward alert not available. Had the compressor replaced and everything is ok now. |
14th Jun 2015 9:28pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Can i suggest starting the car from cold, leave it running for ten minutes (without touching the suspension settings) then press off road height and report back with your findings... |
14th Jun 2015 10:53pm |
Silverwebfox Member Since: 08 Jun 2015 Location: England Posts: 11 |
Apologies for the delay in coming back. Tried the ten minutes as suggested, still would not go to offroad height. Took the car to an independent garage for a full report. It has confirmed that the compressor needs replacing.
21st Jun 2015 9:10pm |
Where in the country are you sir? |
21st Jun 2015 9:33pm |
Mid - Sussex, just north of Brighton. Why may I ask? |
21st Jun 2015 9:44pm |
As we are (hopefully) a trusted site sponsor/independant FF specialist sir... But based too far away from you sir |
22nd Jun 2015 8:09am |
Ah yes, I'd already thought of you but as you say too far away.
22nd Jun 2015 11:09am |
22nd Jun 2015 6:33pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
There is a cheap fix for this ,it is just the piston ring in the compressor I fixed mine for £20.Google it on ebay 'l322 air compressor piston ring' then look up same fix on 'you tube' where there is a 10 min video to show you how to fix it.You may however have to get it 'reset' with a plug in when you have finished ,see the other forum subject on this 'technical' page!! |
22nd Jun 2015 7:17pm |
Waddy Member Since: 02 Jan 2017 Location: Huntingdon Posts: 2 |
Hi there, sorry to raise an old thread but was wondering if this issue was resolved and if so, what the remedy was.
2nd Jan 2017 6:47am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Not sure if your symptoms are similar but if you read this waddy/ might be of some usec
2nd Jan 2017 8:30am |
Seems the same symptoms as above and with mine. Potentially a new compressor unit needed by the sounds of things. Was this the cure for Silverwebfox? |
2nd Jan 2017 8:43am |
