![]() | Home > Technical (L322) > Starting issues 2003 FFRR TD6 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Check continuity in the glow plug wiring loom, could be an internally broken wire...
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
The accepted thinking is that in U.K. climate, glow plugs help the engine to start, but aren't strictly necessary. If you have a problem preventing the glow plugs from heating it might take a few seconds extra turning over to start - that's all. If it was me, I'd want to solve the glowplug problem, but getting it to start reliably is a greater priority.
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 ![]() ![]() ![]() |
Thanks for the responses. I found my probe on my tester wasn't long enough and once I plugged a new glow plug in I was getting 12v.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Well done on getting the glow plugs out! ( I failed !): http://www.fullfatrr.com/forum/topic24161.html
Thank you for the links. I changed the first injector and used a decent injector slide hammer as it wouldn't budge. Leak off kit expected mid week. Will report back |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 67 ![]() ![]() ![]() |
The two injectors which were not working would be black, because each time they glow the soot burns off them. |
Quick update. Performed the leak of test. Injector 6 filled the bottle in less than 10 secs and number 2 filled it about half. Left them with a bit of diesel soaking in while I waited for the injectors to arrive.
