Home > Technical (L322) > Starting issues 2003 FFRR TD6 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8102 |
Check continuity in the glow plug wiring loom, could be an internally broken wire...
30th Dec 2016 1:19pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
The accepted thinking is that in U.K. climate, glow plugs help the engine to start, but aren't strictly necessary. If you have a problem preventing the glow plugs from heating it might take a few seconds extra turning over to start - that's all. If it was me, I'd want to solve the glowplug problem, but getting it to start reliably is a greater priority.
30th Dec 2016 3:24pm |
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 |
Thanks for the responses. I found my probe on my tester wasn't long enough and once I plugged a new glow plug in I was getting 12v.
1st Jan 2017 9:00am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
Well done on getting the glow plugs out! ( I failed !): http://www.fullfatrr.com/forum/topic24161.html
1st Jan 2017 1:13pm |
Thank you for the links. I changed the first injector and used a decent injector slide hammer as it wouldn't budge. Leak off kit expected mid week. Will report back |
2nd Jan 2017 9:40am |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 43 |
The two injectors which were not working would be black, because each time they glow the soot burns off them. |
2nd Jan 2017 1:11pm |
Quick update. Performed the leak of test. Injector 6 filled the bottle in less than 10 secs and number 2 filled it about half. Left them with a bit of diesel soaking in while I waited for the injectors to arrive.
19th Jan 2017 2:13pm |
