Home > In Car Electronics (L322) > Tv DVD reverse camera radio channels lost
Rangie1066
Northern Ireland 2007 Range Rover Vogue SE TDV8 Santorini Black
Hi I wander if anyone could help me
I had a fault with my Range Rover vogue se 2007 tdv8 --when I started the car it stayed on the land rover screen with orange button flashing nothing worked a friend of mine said it could be the Bluetooth Nokia module in the boot at the left which is a common fault -- I bought 1 on eBay and replaced the module ---now the front screen powers up the sat nav works -the radio shows just preset channels it won't let me auto save - I can enter a manual channel -- the tv nor DVD work and will not let me select them -- but I can select them on rear entertainment and they work -- the volume nob doesn't work but works on steering wheel the reverse camera doesn't come on -- I can't view car mpg off road info etc.... on screen
I'm puzzled all I can do is pick manual radio station and use volume on steering wheel
I have looked in boot left there is no sign of water or broken cables
I hope someone can help --thanks in advance merry Christmas
Post #419471 24th Dec 2016 4:00pm
Tony
Hi
I had the same problem, try this . unlock car ,pop bonnet open ,leave door closed but not on latch , walk away for 20 mins .
return with 10 mm ring spanner , open bonnet , disconnect the negative terminal from the battery move away from battery so no accidental re connection , walk away .
Return 2 hrs later do not be tempted to touch anything key fobs etc ,,
short the negative lead to the battery positive lead the spanner makes a good tool for this ( sounds brutal but it works )
hold this connection for 20 + seconds ,
Now reconnect the negative lead to the battery negative ( TRY TO MAKE THIS CONNECTION IN ONE MOVEMENT, NO ON OFF JIG IT ABOUT A BIT )
Now return to drivers door open ( hence leave off catch ) key in ignition turn on but do not start you should have screen up by now start on setting ,time date etc , check tv dvd cd etc .
start engine check trip info and off road view this should work now Thumbs Up did this on mine and it worked Rolling with laughter
Post #419568 25th Dec 2016 8:30pm
Rangie1066
Tony you are an absolute star thanks so much just did your fix and everything back working 👍👍👍👍👍😬😬😬😬😬😬😬
Post #419850 28th Dec 2016 2:19pm
Tony
No problem, glad to help.
Post #419879 28th Dec 2016 6:59pm
The classic battery disconnection procedure Thumbs Up .
Post #419889 28th Dec 2016 8:06pm
