Hi
I had the same problem, try this . unlock car ,pop bonnet open ,leave door closed but not on latch , walk away for 20 mins .
return with 10 mm ring spanner , open bonnet , disconnect the negative terminal from the battery move away from battery so no accidental re connection , walk away .
Return 2 hrs later do not be tempted to touch anything key fobs etc ,,
short the negative lead to the battery positive lead the spanner makes a good tool for this ( sounds brutal but it works )
hold this connection for 20 + seconds ,
Now reconnect the negative lead to the battery negative ( TRY TO MAKE THIS CONNECTION IN ONE MOVEMENT, NO ON OFF JIG IT ABOUT A BIT )
Now return to drivers door open ( hence leave off catch ) key in ignition turn on but do not start you should have screen up by now start on setting ,time date etc , check tv dvd cd etc .
start engine check trip info and off road view this should work now did this on mine and it worked
