![]() | Home > In Car Electronics (L322) > iBus Interface |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Does anyone have one, or any experience?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Yep, if you have the tech know-how to use it.
I've done some research on it.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
What sort of functions does it have?
It allows you to connect NavCoder without all the messing about, you just plug it in the computer and the obd socket in the car (top of pocket under light switch) The lead did come with some BMW software, but I've never installed it, I just wanted to use it to connect NavCoder.... which is free to download and look at...but, you do have to buy a licence to talk to the car....
FYI that link was an example... you can get them in the UK as well, just couldn't be bothered to wade through fleabay |
Will have covered it somewhere in here:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8435 ![]() ![]() ![]() |
Just FYI you can reset the clock to 12 by pulling the fuse, a battery reset will reset the MPG as well although I wouldn't bother as it is so inaccurate it's ridiculous... just pluck a number out the sky and you will be closer to the real MPG...... |
