Home > Off Topic > Engine Management Light on MOT fail?
supershuttle
My son has a Ford something or other but he's asked me to book it in for an MOT over Christmas (when he pays his annual visit) but I think the EML is stuck on. I know there are a few on here who know about MOTs so the question is will it mean an automatic failure if it's on, I know lights for ABS etc are automatic failures but that is probably because there is an underlying cause that might be dangerous - it's actually been on all year as it came on just after the last MOT . Geoff
Post #418895 20th Dec 2016 9:56pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
Yes.
MC
Post #418896 20th Dec 2016 9:59pm
Dolphinboy
Not sure it is a fail as last year my EML came on just before the mot and it was an advisory and still passed.
Post #418908 20th Dec 2016 10:46pm
daveenty
The EML is not a testable item. It's not mentioned in the testers manual though, dependant on the tester, could bring an advisory.
It's what causes it to be on which could bring a failure, usually emissions, like an O2 sensor.
Post #418941 21st Dec 2016 7:57am
supershuttle
Right I'll get it booked in with the light on, if there is something else wrong I'm happy to have it fixed but that light has a mind of its own. I just wanted to be sure it would fail just because the light came on. Very Happy Geoff
Post #418943 21st Dec 2016 8:10am
daveenty
Don't suppose you know what's causing it to light up?
Just that, if it's something minor, it may be prudent to reset it before it makes it's annual jaunt. Smile
Post #418947 21st Dec 2016 8:17am
Dolphinboy
Try giving the MAF a clean. That may help the air intake quality and thus the o2 levels. Not sure how to reset the eml on a ford tho?
Post #418948 21st Dec 2016 8:38am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
If it is driven by devil juice then it could be the EGRV stuck open. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #418950 21st Dec 2016 9:05am
supershuttle
Thanks guys - its Petrol (I don't know if "devil Juice" is petrol or diesel Confused ) but I think I need to clean the MAF on my RR (also petrol) because it runs a bit lumpy on starting but is otherwise OK (not bad for a RR) Geoff
Post #418955 21st Dec 2016 9:30am
supershuttle
Just asked the tester when I booked it in, EML being on is not a fail of itself, however underlying cause might be Thumbs Up Geoff
Post #418963 21st Dec 2016 10:49am
miggit
Whistle EML is usually caused by a sensor going down, which in turn mucks up the fuel mixture.. basically the engine goes in to rich mode.. this will more than likely naff up the emissions and will undoubtedly use more fuel... not much of an issue if it's powered by an engine that wouldn't look out of place on a lawnmower... bit more of a problem when the car is a gas guzzler to start with Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #419115 22nd Dec 2016 3:39am
supershuttle
It's in tomorrow so I'll keep you posted. Geoff
Post #419128 22nd Dec 2016 9:53am
supershuttle
Yep passed no problem, EML on when I took it in, mechanic explained that the problem might be something to do with variable valve timing but passed with no advisory. Emissions etc obviously OK Geoff
Post #419338 23rd Dec 2016 6:24pm
Rob99
Result Thumbs Up
Nice Christmas present from your FF Very Happy 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #419399 24th Dec 2016 12:08am
