Home > Off Topic > Engine Management Light on MOT fail? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3829 |
My son has a Ford something or other but he's asked me to book it in for an MOT over Christmas (when he pays his annual visit) but I think the EML is stuck on. I know there are a few on here who know about MOTs so the question is will it mean an automatic failure if it's on, I know lights for ABS etc are automatic failures but that is probably because there is an underlying cause that might be dangerous - it's actually been on all year as it came on just after the last MOT . Geoff |
20th Dec 2016 8:56pm |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 |
Yes.
20th Dec 2016 8:59pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
Not sure it is a fail as last year my EML came on just before the mot and it was an advisory and still passed. |
20th Dec 2016 9:46pm |
daveenty Member Since: 30 Mar 2016 Location: North West Posts: 34 |
The EML is not a testable item. It's not mentioned in the testers manual though, dependant on the tester, could bring an advisory.
21st Dec 2016 6:57am |
Right I'll get it booked in with the light on, if there is something else wrong I'm happy to have it fixed but that light has a mind of its own. I just wanted to be sure it would fail just because the light came on. Geoff |
21st Dec 2016 7:10am |
Don't suppose you know what's causing it to light up?
21st Dec 2016 7:17am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
If it is driven by devil juice then it could be the EGRV stuck open. Previous cars:
21st Dec 2016 8:05am |
Thanks guys - its Petrol (I don't know if "devil Juice" is petrol or diesel ) but I think I need to clean the MAF on my RR (also petrol) because it runs a bit lumpy on starting but is otherwise OK (not bad for a RR) Geoff |
21st Dec 2016 8:30am |
Just asked the tester when I booked it in, EML being on is not a fail of itself, however underlying cause might be Geoff |
21st Dec 2016 9:49am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
EML is usually caused by a sensor going down, which in turn mucks up the fuel mixture.. basically the engine goes in to rich mode.. this will more than likely naff up the emissions and will undoubtedly use more fuel... not much of an issue if it's powered by an engine that wouldn't look out of place on a lawnmower... bit more of a problem when the car is a gas guzzler to start with Yesterday I couldn't spell Engineer... Today I are one!
22nd Dec 2016 2:39am |
It's in tomorrow so I'll keep you posted. Geoff |
22nd Dec 2016 8:53am |
Yep passed no problem, EML on when I took it in, mechanic explained that the problem might be something to do with variable valve timing but passed with no advisory. Emissions etc obviously OK Geoff |
23rd Dec 2016 5:24pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1434 |
Result
23rd Dec 2016 11:08pm |
