Home > Technical (L322) > V8 Timing chain |
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 |
Well after a quiet few months the old girl has decided it was time for a little issue to keep me interested !
4th Dec 2016 3:20pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I think that will do the job. Can't really confirm every part, but that looks comprehensive. I think there were a few older threads with a list or two.
4th Dec 2016 7:13pm |
Thanks for the reply John,
4th Dec 2016 9:24pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have just done mine if you have a look at a few posts into the thread below.
5th Dec 2016 12:19am |
when i did my chain job, i didnt know the state of the vanos seals. it wasnt a particularly easy job, but following the guide, hooking out the old, and carefully placing in the new, isnt too hard, but then the 'setting' of the units, ie you use this tool to crush the units, to make the seals 'seal' is a big job, in that you need access to a decent sized vice, on a decent bench, and a five foot pole!. not a little thing in a wooden shed, as you need the pole and a lot of force, to set them, and a shed would/might just twist and collapse.
5th Dec 2016 7:40am |
I agree on the vanos, i have a fairly good vice, used the 5 ft pole from the crank bolt tool so was easy but the seals were fiddly, the harder plastic ring i killed one trying to get it in but luckily had bought the spare recommended by beisan.
5th Dec 2016 8:11am |
