Home > Technical (L322) > engine temperature |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I changed my alternator on the TD6 last week and I found the easiest way to do this was to remove the radiator rather than the power steering pump. Whilst the rad was out, I decided to get it leak tested as I keep losing coolant.
5th Dec 2016 12:56pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
Could be a micro fracture in your expansion tank, they tend to crack at the corners. Best way to check is to get it up to temp and hold a small mirror or such and you'll see steam and moisture on the cold mirror.
5th Dec 2016 1:53pm |
Yes, but that would show up on a pressure test wouldn't it? |
5th Dec 2016 4:19pm |
Possibly but it has to be hot to get the expansion tank to expand enough to leak. ______________________________
5th Dec 2016 4:28pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
there is a bleed screw on the EGR cooler at the front of the engine, another on the rail that runs down the side of the head and a third on the header tank... so yes they do need bleeding, they also need to be run with the cap off until they get to temp and topped up as you go.....
6th Dec 2016 7:29am |
