Home > Maintenance & Mods (L322) > Grey plastic trim water marks? Anyway to clean and restore?
lazylabs
Hi
All my grey trim is discoloured with what looks like dark water marks. Tried a few cleaners but nothing touching it.
Is there anyway of cleaning these off?
Or is it a removing and paint job?
TIA Current Family:
2012 FFRR 4.4 TDV8 Westminster
2013 Jaguar XFs 3.0d Sportbrake
2008 FFRR 3.6 TDV8 VSE (Gone)
2008 Ford Mondeo mk4 2.2tdci (Gone)
2006 S Class 320 CDI (Gone)
1998 P38a 4.6 VSE Oxford Blue 98k (Gone)
Vx Vectra C Estate 1.9cdti 150 (with a few twists) (Gone)
Other LR's in Family (2019 4.4 TDV8 AB)
Post #415160 24th Nov 2016 6:06pm
peanut butter... Thumbs Up ... - .- -.
Post #415166 24th Nov 2016 6:38pm
jonnyboy54321
That looks exactly like tfr damage to me - been too strong or gone over the dwell time. My local car wash did the same to mine Big Cry
Spoke to a valeter pal - "repaint time mate sorry".
However, some g3 compound on a cloth and a lot of hard work has largely brought them back - so no repaint after all Thumbs Up
Not done the bonnet one yet, can't reach Rolling with laughter 2007 Vogue TDV8 with 255/55/20's fitted
Post #415168 24th Nov 2016 6:56pm
lazylabs
I thought peanut butter was for restoring faded colours back to normal? Oils and all that...
This looks like bleach splash but in reverse. Gone darker rather than lighter.
The grill, side vents and bonnet vents are all light this. I'll have a go with some G3. See what I can do.
Anybody ever used the wurth plasti PT? Current Family:
Post #415183 24th Nov 2016 7:41pm
jonnyboy54321
See above! Tfr damage... 2007 Vogue TDV8 with 255/55/20's fitted
Post #415184 24th Nov 2016 7:43pm
lazylabs
Yeah I agree. Tfr could well be the problem. It's certainly something that's been sprayed on.
G3 it is then. Current Family:
Post #415185 24th Nov 2016 7:50pm
jonnyboy54321
Yours isn't as bad as mine was, try some g10 first, may do ok.
You may find it easier to take trims off and sit down to do it in the warmth! Just remember to water-lube your compound.
Let us know how you get on! 2007 Vogue TDV8 with 255/55/20's fitted
Post #415187 24th Nov 2016 7:55pm
lazylabs
Thanks
Will give this a go. Anything to improve them.
I'll take some before and afters. Current Family:
Post #415196 24th Nov 2016 8:55pm
jonnyboy54321
Found some of mine as it turns out! Cloth tells you all you need to know!
Post #415214 24th Nov 2016 10:34pm
lazylabs
That's cracking that is. Much much better. Current Family:
Post #415233 24th Nov 2016 11:43pm
jonnyboy54321
Think yours is worse than mine tbf looking at pics!
BTW you have a pm (unrelated) 2007 Vogue TDV8 with 255/55/20's fitted
Post #415234 24th Nov 2016 11:45pm
lazylabs
Yes looks like it. But looks like the same problem so hopefully get the same results.
I've replied.
Thumbs Up Current Family:
Post #415237 24th Nov 2016 11:53pm
lazylabs
Well the answer has been found. No more marks on the plastic grill and vent trim.
Before and after picture.
Tried quite a few different products but the best and by far the quickest and cheapest.
Brasso wadding.
Few rubs and the marks disappeared and left with like factory finish. Current Family:
Post #415719 28th Nov 2016 6:21pm
jonnyboy54321
That's interesting, very interesting.
Will use that on my bonnet vent then instead of G3 Thumbs Up 2007 Vogue TDV8 with 255/55/20's fitted
Post #415729 28th Nov 2016 7:05pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
S'cuse my ignorance, but what is Tfr damage? Confused
Post #415733 28th Nov 2016 7:54pm
