![]() | Home > In Car Electronics (L322) > DAB V Heated rear window? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
the dab antenna is in the rear and rear side screens...the electronic boxes are located behind the rear cubbys...
666SVT Member Since: 30 Oct 2016 Location: Wigan Lancashire Posts: 5 ![]() ![]() ![]() |
Cheers, I'll have look in the back Tomorrow. It has been pretty wet here last week or so. |
is that when the problem started ? ... - .- -.
Yep could be as I only really noticed it a couple of days ago. Will delve into the back end Tomorrow for a moisture check👍 |
Well had a look in the rear Today and all is bone dry. Checked and tightened connections and earths but problem persists?
Biffo Member Since: 26 Aug 2016 Location: Wiltshire Posts: 82 ![]() ![]() ![]() |
I have exactly the same problem on my 320d BMW (2012). I've just assumed the heated rear screen must interfere with the DAB antenna somehow. I bought the car in May 2015 but only noticed the problem in the October when I started using the heated rear screen. Its a PITA ! |
rangie_mike Member Since: 18 May 2015 Location: W Sussex Posts: 29 ![]() ![]() ![]() |
I get the same issue on mine - I just assumed the power through the heating element corrupts the DAB signal. Current : Range Rover 5.0 SC 2011 Orkney Grey
