Home > In Car Electronics (L322) > DAB V Heated rear window?
666SVT
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Anyone had this one? When I have the DAB radio on in my 2010 Vogue, As soon as I switch on the heated radio window
the radio cuts out and shows No Signal on the display? Switching rear window heating off restores the radio signal. Not a power consumption issue as such as I can create a massive load with heated seat etc and it doesn't happen?
Anyone got any ideas?
Cheers Col, Long time lurker first time poster Smile
Post #415147 24th Nov 2016 4:01pm
the dab antenna is in the rear and rear side screens...the electronic boxes are located behind the rear cubbys...
i would check all connections and in particular the earth connections and also check that there isnt any water ingress.. ... - .- -.
Post #415148 24th Nov 2016 4:14pm
666SVT
Cheers, I'll have look in the back Tomorrow. It has been pretty wet here last week or so.
Post #415162 24th Nov 2016 5:09pm
is that when the problem started ? ... - .- -.
Post #415165 24th Nov 2016 5:35pm
666SVT
Yep could be as I only really noticed it a couple of days ago. Will delve into the back end Tomorrow for a moisture check👍
Post #415174 24th Nov 2016 6:08pm
666SVT
Well had a look in the rear Today and all is bone dry. Checked and tightened connections and earths but problem persists?
Think this maybe a tricky one to suss out?
Post #415326 25th Nov 2016 2:38pm
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I have exactly the same problem on my 320d BMW (2012). I've just assumed the heated rear screen must interfere with the DAB antenna somehow. I bought the car in May 2015 but only noticed the problem in the October when I started using the heated rear screen. Its a PITA !
Post #415341 25th Nov 2016 3:46pm
rangie_mike
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Orkney Grey
I get the same issue on mine - I just assumed the power through the heating element corrupts the DAB signal. Current : Range Rover 5.0 SC 2011 Orkney Grey
Previous : P38 4.6 Vogue 2000, Audi A4 Avant 2.5Tdi Quattro Sport, RR Classic 3.9 Vogue, BMW M535i, BMW 525e, BMW 2002tii, Austin Metro
Post #416809 5th Dec 2016 10:43pm
