![]() | Home > Technical (L322) > Engine Supplier/Builder Needed for a TDV8 |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
Mark
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
"Most" of the places on eBay are the rip off firms, whatever place you find make sure you do lots of googling on not only the name but the address and phone number as well, they change name at the drop of a hat and pretend they are a different company just before the flood of bailiffs turn up...... Pete
Not sure if they do these engines but talk to C&K Engineering in High Wycombe. I used them for many years on a multitude of engines I had in various rally cars. Their work was nothing short of fantastic. I recall they even made a set of main end bearing from scratch, i.e. molten white metal, for a block which had been line bored and was thus oversized on the outside of the mains.
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
I've also been down this road. In the end I opted to do the rebuild myself. Nobody wanted to touch the TDV8.
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
Guys,
Fella, We've all been there in some way or other so don't be too despairing. The 'charger can't have too much wrong - check the basics like cam timing. Just remember, Suck Squeeze Bang Puff and as long as it's all in the right sequence it will run.
Well. First off. I have timing tools, which I can lend to you to get yours going! I'd need them back though as I've a block here which I might like to put some heads on!
I also have a piston ring compressor which I don't need. I can send that over aswell! Infact if you want I can lend you the whole lot if it's of any help. |
If we can find someone to do a decent rebuild I have at least two core units that could be rebuilt, as people say its not rocket science, but getting new bits that are accurate is a problem, along with a good machine shop, the cranks are a mare to grind.
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Ring Engineering in Hayes are exceptional chaps. |
Thanks guys for all your offers of kit and advice. I'm still agonising over this. Can I ask a few more questions of those of you that have done this before?
Engine will come out in half a day. You would need to get the air-con evacuated before starting, don't just let the gas escape to atmosphere.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Ok, thanks again for the info. As you say.....eight of everything is a bit of a nightmare scenario. You are right....no point being in that far and not doing the other head and the oil pump etc. I'll get the bits I know of now priced up...I'm hoping crank, rods etc are all good.
