![]() | Home > LPG > valve lube |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
should i fit valve lube kit to my 4.2 sc ,,80,000 miles or not some say do some say defo not |
Foulolron Member Since: 05 Aug 2015 Location: East Yorkshire Posts: 29 ![]() ![]() ![]() |
I belive its only the BMW engines that doesn't require flash lube |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8491 ![]() ![]() ![]() |
Yep, agree, you do need it for that engine...
how much am i looking at to get them changed |
if i do get the kit how long will the seats last as opposed to not fitting them .thanks |
Depends on too many variables to hazard a guess, depends how you drive and how the gearbox treats the engine, it usually takes many 10's of thousands of miles to do significant damage, but could do it in a lot less, seen it done in less than 12,000 miles on some engines...
thankyou |
