Home > LPG > valve lube
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
valve lube
should i fit valve lube kit to my 4.2 sc ,,80,000 miles or not some say do some say defo not
Post #414989 23rd Nov 2016 7:44pm
Foulolron
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I belive its only the BMW engines that doesn't require flash lube
Post #415034 23rd Nov 2016 10:51pm
Yep, agree, you do need it for that engine...
Or get the valve seats changed.....Thumbs Up Pete
Post #415043 23rd Nov 2016 11:15pm
Harlin
valve
how much am i looking at to get them changed
Post #415059 24th Nov 2016 12:14am
Harlin
valve lube
if i do get the kit how long will the seats last as opposed to not fitting them .thanks
Post #415062 24th Nov 2016 12:19am
Depends on too many variables to hazard a guess, depends how you drive and how the gearbox treats the engine, it usually takes many 10's of thousands of miles to do significant damage, but could do it in a lot less, seen it done in less than 12,000 miles on some engines...
If it has been run without lube for any length of time, get the compression in the cylinders checked, if it is low then you need new valve seats (exhaust) and valves before fitting a valve lube. Obviously check for worn rings before diving in as it could have low compression and be nothing to do with LPG...
Replacement seats and valves will be expensive as there is a lot of labour and machining, I would guess well over �1,000.
The reason the later ones are worse is down to the bean counters again, using inferior materials and parts, the cheapest they can get away with.... Pete
Post #415076 24th Nov 2016 1:31am
Harlin
valve lube
thankyou
Post #415078 24th Nov 2016 1:42am
