Hello Everyone. I'm currently rebuilding my engine in my TDV8 as the EGR failed and damaged two pistons in the process. I've another thread open, however I would like to confirm some things regarding how to the set the timing.
I never removed the LH bank from the vehicle and left the chain attached. When I lock this using the special tool, I can then insert the pin into the engine block. To me this is the point whereby 2/ of 3 parts of the engine is timed.
When I installed the new head on the RH side we were unable to attach the chain (with tentioner removed)unless with didn't have the cam in it's final position. We had to attached the chain an then place the special tool onto the head to ensure the correct position. Is this the correct method?
However, even though both heads and block started in the same position, we discovered that after one revolution of the crankshaft the engine heads were no longer identical. It was my understanding that both these sides have to the same position 12 O Clock (Kinda of like a mirror). What could we be doing wrong. We hand't tighten the tentioner, and perhaps this was the cause of the issue. We are only learning - anyways no harm done, we just have to repeat the process.
Should both heads be at the 12 o Clock position at the same time? Could the chain be forward 1 tooth and therefore effecting the timing?
Really can't see anything else we are doing wrong. If someone was able to offer advice or even chat quickly on the phone we'd really appreciate it! We've come this far and I believe the hardest part is over! Thanks in advance.
 | Click image to enlarge |
