Home > Technical (L322) > Umstable at high speed braking.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi everyone.
My 06 td6 misbehaves when braking at high speeds.
It also goes right when i accelerate.
At hard decalaration it is like uneven braking i think it goes left.
And back of the car feels loose.
03 td6 we also own is much more stable.
Post #414225 18th Nov 2016 1:19pm
Weegie
Could be a number of things. I would look at sticking caliper then roll bar drop links for starters. John
GAP iiD BT-Sold
Post #414228 18th Nov 2016 1:24pm
Bluegreygreen Rangie
Australia
It might be worth feeling the temperature of the wheels after some driving, Like Weegie pointed out a caliper could be binding or a wheel bearing tight etc however if so that particular wheel will be hotter to touch than the others
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #414249 18th Nov 2016 3:23pm
kbald
I had this and it was two things! First sticky rear caliper and the rear anti roll bar drop links needed replacing! So exactly as the previous posters said!
New pads and discs and replacement roll bar links solved the problem! Not too expensive if you change them yourself
Post #414261 18th Nov 2016 5:01pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
It could be tracking or worn joints, is check the upper and lower joints on the rear in particular.
Post #414284 18th Nov 2016 7:23pm
umitbat
I changed right rear upnlow joints.
It had no affect
I have a hitting sense when press brake.suddenly onnthe front.
Can front carrier joint cause this?
Will check wheels also.
Post #414330 19th Nov 2016 7:31am
