![]() | Home > General > RR Thoughts |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
in my reading the td6 is ok but the tranny is terrible. The zf 6 speed and electronic lockers are excellent. People seem to love the tdv8. I would get the tdv8 if you want but the gas v8s in 06-09 are excellent too. The interior is redone and is tougher and more modern. I would also suggest finding one with a rear electronic locker. The step up is worth it. 07-09 are the most reliable l322s you can buy. OffRoadRover.com An American Western Range Rover Off Road Blog |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
same here love to know if a conversion is available if so id book mine in straight away forsure |
@ miggit
so as http://bb4wa.com/simply-put-4x4-transfer-case/ says is it possible to change td6 transmission if so what would be difference of single to two speed transfer box ? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I'm sure someone will work it out eventually. ______________________________
Right the facts as I know them... the Range Rover TD6 was saddled with the feeble GM 5L40E and a 2 speed transfer box, the X5 was also give the feeble GM 5L40E box but a single speed transfer box, as they were never intended to go offroad.... The later X5's were given a much higher output engine and as a result they also got the ZF 6 speed gearbox... not because it was better, more like it could take the power and the GM couldn't.
From my understanding reading rrphill's great write ups is that the zf 6 speed is revolutionary design difference with far less parts that is far more reliable. The inventor behind the zf 6, retired then protected the design and sold it to zf as far as i understand.
Yes the ZF is a better gearbox, but it wont play with the TD6 ECU's |
