Home > General > FF gone
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
FF gone
Well after 2 1/2 years of ownership I said goodbye to my FF yesterday, transfer motor has been playing up a bit for a few months, but unplug and plug it back in and all was ok for a while, so with that in mind and needing a couple of tyres and bit of rust on rear wheel arch I decided to cut my losses. Sad to see it go but maybe have a newer one in a couple of years.
Thanks for all the help and advice i will hang around because im sure i'll be anFF owner once again some time in the future.
Post #413489 14th Nov 2016 12:10pm
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
Yes I got to that point with my '04. Looking at the electrical connections I could see that just old age/natural humidity was causing slight surface corrosion everywhere in the electrical system and even though there was no water ingress I suspected that in another year or so significant surgery was going to be needed on some of the looms/connectors.
My biggest worry was with the connectors I couldn't get at easily - like the transfer box.
So had a good look around at other vehicles and nothing compared to a FFRR - in fact I didn't even want to test drive anything else - so had to get a newer RR.
So the big question Jimmy C is - What have you replaced it with?
Knips.
Post #413494 14th Nov 2016 12:27pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Oh that's a shame JC. Hope you don't pine too badly for the FF.
Well actually that's not true, I hope you pine just enough to make you have to get another FF really soon Laughing Laughing Good luck 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #413522 14th Nov 2016 3:11pm
Jimmy C
Yeah I've thrown a lot of money at it this year and at some point you have to weigh up the value of the car against what your spending. I let it go to a dealer as i think they are quite a hard sell privately with the faults it had, now driving an astra for a while, definitely not an FF but what compares?? Im sure ill be back in a couple of years when i can have a bigger budget and get something abit newer.
Ive found that buying in at entry level FF ie-an early L322 comes with the same repair costs as a newer one but much more frequent, something I knew but at some point you have to cut your losses.
Post #413869 16th Nov 2016 9:35am
