Home > Technical (L322) > Oh dear, TD6 2003 auto clutch going? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
That all sounds pretty normal for a TD6.... it doesn't matter how hard you press the loud peddle it wont accelerate any quicker... regardless of what mode the gearbox is in... in fact the only thing that sport mode does is make more noise Try and find a TD6 owner near you and either cadge a ride or give them a lift... either way you'll know if it's your car or it's "normal" TD6 behaviour
12th Nov 2016 1:27am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
PM Cam-Tec-craig he's Gloucestershire based..... There is nothing that can't be fixed with a hammer😜😜
12th Nov 2016 9:25am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
You need diagnostic's, to show what fault's are coming up. To be fair to your dealer, if they just serviced it , then they probably wouldn't have known of the issue.
12th Nov 2016 11:18am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
When I press the accelerator on my Td6 it goes faster, no apparently not keeping up with the engine speed.
12th Nov 2016 11:45am |
