5hp24 oil cooler and thermostat | |
I am interested in any thoughts on the reliability of the transmission oil cooler and thermostat.
I have them off the car and am looking to replace after engine and box rebuild.
I have cleaned the oil cooler with a contiuous flow of kero, so no oil blockages.
Now to the general question, i have heard of this failing and letting water into the box, is this common or very rare?
Does anyone have any info on this? I dont want to throw money away, but i also dont want to blow the rebuilt box.....
Second question the oil cooler thermostat, i have heard of this going bad and only using heat function. Is this common, or rare. Also i live in relativly pleasant climates, uk, so i dont get really cold weather. Does it need the warm function?
Could it just be plumbed straight off the bottom of the rad to remove the thermostat? As i see it the thermostat is mainly there for the likes of camada and its winters....
Talking of rads i have not tested the flow of that, main rad, properly yet but it does seem good, bottom rows that is, using the tech note as a guide. I will do that when all pipes are refitted, so far i have carried out test with numerous pipes missing....
