Home > Technical (L322) > Coolant colour.
ije44
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Coolant colour.
Hello all,
I bought a 1 litre top up bottle of coolant today from the dealer.
I didn't even think to check the colour at the time but when back at home, I thought about it and checked. The LR coolant was green, whereas my car has orange coolant.
Am I right in thinking you cannot mix these two fluids and therefore have LR given me the wrong stuff?
It's a 2007 TDV8.
Thanks in advance.
Ian
Post #407571 3rd Oct 2016 7:26pm
pepa80
Spain 2005 Range Rover Vogue Td6 Giverny Green
Hi Ian.
As far as I'm concerned, coolant color is a comercial issue, I mean, it is not necessarily related to coolant specifications. For instance, you might find green and orange colors within the same brand name and with the same specifications, or not.
Before mixing coolants, check % concentration of water and coolant and temperature operating ranges (against freezing and against boil-over).
Also, you may find in the car instructions which are the coolant fluids recommended by RR. And never ever, except an emergency, fill in with tap water.
Regards
Pepa
Post #408656 10th Oct 2016 3:27pm
I wouldn't be so quick - I thought there were some ingredients that were not compatible and reduced the overall effectiveness...... I could be wrong and have fallen for some sort of marketing hype though....
Post #408659 10th Oct 2016 3:54pm
I just googled - this site says no -
http://www.autoblog.com/2009/12/28/coolant-color/
Do some proper research......
Post #408660 10th Oct 2016 3:56pm
As alistair says i wouldnt be quick to add it, generally speaking the orange coolant is OAT coolant and this shouldn't be mixed with regular blue/green coolant. Thumbs Up
Your car should have Orange/pink coolant in it from the factory, so it has the right stuff in there. TBH i wouldnt worry about the brand, just some ready mixed orange coolant from Halfords will do the trick Thumbs Up used it as top up in my 3.6 with no issues at all
http://www.halfords.com/motoring/engine-oi...e-2-litres There is nothing that can't be fixed with a hammer😜😜
Post #408667 10th Oct 2016 5:31pm
ije44
Thanks all for your replies.
I didn't use it, didn't want to risk it so I will be taking it back.
I kind of knew the answer rolling around in the back of my mind somewhere, was just after a little reassurance from the good folk on here.
Since the original posting I have done a bit of research and looked at rave and I know what's what now.
Cheers,
Ian
Post #408673 10th Oct 2016 7:40pm
