Home > Maintenance & Mods (L322) > fuel filter location |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
On the early petrol it was behind a plastic cover in the area you describe and access wasn't the best. The cover iirc just unclipped V8 or else ... |
29th Sep 2016 8:03pm |
Are you sure it has one ? the 4.2 doesn't . Something to do with restricting the unrelenting flow of fuel or something like that 2008 MY Supercharged
30th Sep 2016 1:14am |
DocD Member Since: 11 Mar 2015 Location: Johannesburg Posts: 12 |
That would make sense, as the little cubby in front of the rear right wheel which should house the filter has only a fuel line (large calibre). Running through it.
30th Sep 2016 6:36am |
There will be a filter in the tank , it just doesn't need changing at service time . I'd suspect the pump as well . 2008 MY Supercharged
30th Sep 2016 6:59am |
