Home > Maintenance & Mods (L322) > fuel filter location
DocD
South Africa
Could i please get help on locating the fuel filter on a 2010 5.0 SC?
I was under the impression it was just below the fuel tank on the side opposite the filler cap, but i have been unable to locate mine Confused
Thanks in advance.
Post #407024 29th Sep 2016 7:44pm
fisha
On the early petrol it was behind a plastic cover in the area you describe and access wasn't the best. The cover iirc just unclipped V8 or else ...
Post #407025 29th Sep 2016 8:03pm
Are you sure it has one ? the 4.2 doesn't . Something to do with restricting the unrelenting flow of fuel or something like that Big Cry Laughing 2008 MY Supercharged
Post #407066 30th Sep 2016 1:14am
DocD
South Africa
Misfire
That would make sense, as the little cubby in front of the rear right wheel which should house the filter has only a fuel line (large calibre). Running through it.
That complicates my issue a bit as I'm getting misfire codes on all 8 cylinders as well as an insufficient fuel code. Could it be the pump? There must be some sort of filter pre injector?
Post #407080 30th Sep 2016 6:36am
There will be a filter in the tank , it just doesn't need changing at service time . I'd suspect the pump as well . 2008 MY Supercharged
Post #407084 30th Sep 2016 6:59am
