![]() | Home > Technical (L322) > Wet front passenger side carpet - not sunroof leak |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
Just bumpin this up ........hoping for some advice.
mariner30 Member Since: 12 May 2016 Location: SW Scotland Posts: 17 ![]() ![]() ![]() |
Did you ever get this fixed or even get an answer? 2003 TD6 SE model with EGR removed
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
The greasiness you mention is typical for coolant, so yeah, I would agree with the thought that its the heater matrix.
Update : its still leaking sporadically.....not had the time to do anything car related as been away on work for the last few months. However its still on my list of a few things to do...... but the good news it did sail through its MOT last week with no advisories! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I should imagine you can do insitu I had the trim off last week and if you disconnect pipes in the engine bay that should give you enough room |
