Home > General > RAVE
Madyaker
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
RAVE
Now I know my generation isn't completely computer literate but I'm not a total idiot. I have downloaded rave several times (including from this site) and usually get blank or unopenable files. I have got one copy that actually has a load of pdf files that I can see but the best of them only gives exploded diagrams and explanations of what the mechanical bits are. Can someone give me a SIMPLE explanation of where the files are that tell you which bits to remove in which order to get at stuff ? A la a Haynes manual ? I run a Macbook pro so is this maybe the issue ?
Thanks in advance folks.
Post #406697 27th Sep 2016 9:13pm
n1cktdv8
Any other disappointed 40 year olds click this and expect an invite to an all-nighter Mr. Green Is this where I put the car details and a bit about myself ?........
Post #406702 27th Sep 2016 9:26pm
mjdronfield
You should end up with a folder with files in..... You should have a rave executable file that you run, that works the pdfs for you.
Don't think you can access them directly....
I created a shortcut to that executable from my desktop.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #406708 27th Sep 2016 10:05pm
If you are running a Mac, you may need to create a virtual machine running Windows XP, then, having placed all the downloaded files there, run the RAVE executable, this will open up the program that displays all the pdfs for you .....
Many copies of RAVE are security protected, meaning this is the only way to fully view everything. .
Post #406711 27th Sep 2016 10:45pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
The RAVE program itself is just a fancy way of indexing the pdf's and if all you want is the manuals it can be bypassed and just view the pdf's directly.
Download the Rave zip file which is in the Wiki:
https://docs.google.com/uc?id=0Byv5LFgQZql...t=download
Once downloaded unzip the folder to create an expanded Rave folder (which if you have pdf's you have probably got that far).
On a Mac either just stick in Finder search 'wmln022n' which is the 'Service Procedures' Manual or search through the 'Rave/pdf/LM' folder for the same.
The other manuals for the L322 are in the same folder, you've been looking at 'wmln021n' which is 'System Description and Operation' manual.
If you don't want to download then there is an online version of the same here:
http://workshop-manuals.com/landrover/l322...ition_nas/
Bear in mind that they all are the North American manuals, the Wiki doesn't contain UK manuals only an individual copy of the UK System Description & Operation Manual.
You can buy paper copies of the official manuals published by Brooklands Books:
Part Number LRL0477 is the UK L322 2002-2005 Workshop Manual (Service Procedures)
Part Number RR02KEMBB is the UK L322 2002-2005 Electrical Library and Electrical Circuit Diagrams combined
Post #406717 27th Sep 2016 11:43pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I think I remember have some trouble at first but then found the PDF files. I use Nook or other PDF viewers. Works fine.
Post #406727 28th Sep 2016 1:32am
Got my whistle out and everything Big Cry 2008 MY Supercharged
Post #406728 28th Sep 2016 2:42am
Madyaker
Thanks Weejock, Ive finally found what I'm looking for ! Very Happy
Post #406818 28th Sep 2016 4:54pm
