![]() | Home > General > RAVE |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Any other disappointed 40 year olds click this and expect an invite to an all-nighter |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
You should end up with a folder with files in..... You should have a rave executable file that you run, that works the pdfs for you.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
If you are running a Mac, you may need to create a virtual machine running Windows XP, then, having placed all the downloaded files there, run the RAVE executable, this will open up the program that displays all the pdfs for you .....
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
The RAVE program itself is just a fancy way of indexing the pdf's and if all you want is the manuals it can be bypassed and just view the pdf's directly.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I think I remember have some trouble at first but then found the PDF files. I use Nook or other PDF viewers. Works fine. |
Got my whistle out and everything ![]() Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
Madyaker Member Since: 13 Apr 2015 Location: Wigan Posts: 39 ![]() ![]() ![]() |
Thanks Weejock, Ive finally found what I'm looking for ! |
