Home > Technical (L322) > HDC Inactive and Air suspension inactive |
Hi Guys,
1st Dec 2010 9:04pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Good luck, seems to be the "Holy Grail" of RR questions............ |
1st Dec 2010 9:06pm |
Not what i wanted to hear. |
1st Dec 2010 9:22pm |
No idea how old the battery is. Got the car in June and haven't had a problem with it. Looks quite new but that doesn't mean much. |
1st Dec 2010 9:47pm |
Just put new battery (That I charged for 24 hours on mine) still HDC inactive/ Air Susp........
1st Dec 2010 9:48pm |
have you had any faults read? Might need a reset then be ok. |
1st Dec 2010 9:52pm |
EAS Kicker on route to my door now |
1st Dec 2010 10:04pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
a bit more info here;
1st Dec 2010 10:29pm |
Found this-
4th Dec 2010 6:33pm |
So what is it then landrover? low ambient temperature, low battery voltage or ABS ECU.... 2004 black Vogue TD6 |
4th Dec 2010 9:06pm |
Your guess is as good as mine, could be all of the above!........... |
4th Dec 2010 9:13pm |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 |
all the above at random maybe ?
4th Dec 2010 10:13pm |
If starting the car in cold weather does cause a drain on the battery voltage, therefore triggering the lights/warnings etc, I'm going to attach a battery pack to the car when I start it tomorrow, hopefully boosting the charge enough to not trigger the warnings. Will see what happens....
4th Dec 2010 11:23pm |
I know your getting the suspension message too but i have always got hdc inactive, this alone is without a doubt linked to the battery. I got it everytime i started but with a new battery i only get it if the range rover has not been used for a few days. Give it a good run and i dont see it for a while, few short runs, leave her parked for a few days then "bong" its back. Basically even with a new battery it needs to be 100% charged, i only get for a few seconds after starting then its gone so never hard faulted on mine, are your warnings on permanently? The cold possibly aggravates the battery related problem but dont know what the ABS ECU has to do with it other than a electrical gremlin land rover has traced back to this. Good Luck. 2004 black Vogue TD6 |
5th Dec 2010 12:11am |
