Home > Technical (L322) > HDC Inactive and Air suspension inactive
Hi Guys,
Came out of work tonight and fired up the beast. Temp was reading -0.5C but as i went through the key positions the dreaded display pinged up "HDC Inactive" & "Air suspension inactive" Big Cry . Reversed out the space and turned the car off, though i would have to do "lock to lock" to clear the air suspension as I still had the light on the hight display. As i turned the key back to start again i had no faults and she drove home fine. Very Happy
Over the past few month i have every now and again had the HDC fault but its only just pinged up then cleared straight away. Confused
Any ideas what could be the cause? Was she just Censored off being left in the cold all day and had a mood swing or could there be something more to it?
Thanks in advance
Rob
Post #40437 1st Dec 2010 9:04pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Good luck, seems to be the "Holy Grail" of RR questions............ Sad
Post #40438 1st Dec 2010 9:06pm
Big Cry Not what i wanted to hear.
Post #40441 1st Dec 2010 9:22pm
JW911
How old is your battery? The first thing to "ping" if the charge drops is "HDC Inactive". Mine does it if it has been left for a week and did it routinely before I changed the (five year old) battery. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #40442 1st Dec 2010 9:42pm
No idea how old the battery is. Got the car in June and haven't had a problem with it. Looks quite new but that doesn't mean much.
Post #40443 1st Dec 2010 9:47pm
Richcl
Just put new battery (That I charged for 24 hours on mine) still HDC inactive/ Air Susp........
(Yes I did steer lock to lock after re-attaching battery)
Post #40444 1st Dec 2010 9:48pm
have you had any faults read? Might need a reset then be ok.
Post #40445 1st Dec 2010 9:52pm
Richcl
EAS Kicker on route to my door now
Post #40448 1st Dec 2010 10:04pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
a bit more info here;
http://rangerovers.net/repairdetails/airsu...aults.html 2004 black Vogue TD6
Post #40454 1st Dec 2010 10:29pm
Richcl
Found this-
http://forum.landrovernet.com/showthread.p...-TD6/page2
Taken from above thread-
"HDC Inactive" Message - Fault Found
Took Range to Stealer this morning and I have to say I was impressed. Very helpful and honest.
Plugged Range upto computer and found No Codes stored in any of the ECU's.
They explained that the reason why the "HDC Inactive" Messages Displays.
Technical Service Bulletin No. LM206-002, 04 January 2005
Subject/Concern: Range Rover (LM) - HDC Inactive Message after Engine Start in Low Temperatures.
Models: Range Rover (LM) 2002 - 2006 Engine: TD6
Markets: All
Section: 206-09
Section: Brakes
Summary: In low ambient temperatures the "HDC INACTIVE" message may be displayed during and/or shortly after cranking the engine.
NOTE: HDC functionality is NOT effected, this is a message display error only.
Cause: Low batter voltage during engine cranking triggers the message display.
Action: Should a customer express concern regarding the above, refer to the Service Instruction detailed in this Bulletin in order to replace the anti-lock braking (ABS) electronic control unit (ECU)
Post #40849 4th Dec 2010 6:33pm
letsavit2
Richcl wrote:
Found this-
Markets: All
Section: 206-09
Section: Brakes
So what is it then landrover? low ambient temperature, low battery voltage or ABS ECU.... Rolling Eyes 2004 black Vogue TD6
Post #40872 4th Dec 2010 9:06pm
Richcl
Your guess is as good as mine, could be all of the above!........... Big Cry
Post #40876 4th Dec 2010 9:13pm
bogie
all the above at random maybe ?
...I have the trans prog error....on cold mornings, at random it seems ....sometimes just shift into neutral and back to park and it goes away ...got to be a bit of damp a in dodgy sensor somewhere I reckon
/typical British car I guess, used to be called "character" whereas nowadays its software bugs LOL Wink cheers
bogie
Post #40884 4th Dec 2010 10:13pm
Richcl
If starting the car in cold weather does cause a drain on the battery voltage, therefore triggering the lights/warnings etc, I'm going to attach a battery pack to the car when I start it tomorrow, hopefully boosting the charge enough to not trigger the warnings. Will see what happens....
(Would have liked this sorted, as i'm doing a 700 mile round trip next week to Scotland, would rather not have these warning lights on.) Well I suppose the battery will get a good charge! Very Happy
Post #40889 4th Dec 2010 11:23pm
letsavit2
I know your getting the suspension message too but i have always got hdc inactive, this alone is without a doubt linked to the battery. I got it everytime i started but with a new battery i only get it if the range rover has not been used for a few days. Give it a good run and i dont see it for a while, few short runs, leave her parked for a few days then "bong" its back. Basically even with a new battery it needs to be 100% charged, i only get for a few seconds after starting then its gone so never hard faulted on mine, are your warnings on permanently? The cold possibly aggravates the battery related problem but dont know what the ABS ECU has to do with it other than a electrical gremlin land rover has traced back to this.
Good Luck. 2004 black Vogue TD6
Post #40890 5th Dec 2010 12:11am
