Home > Technical (L322) > Windscreen wipers go thud thud thud thud thud thud thud thud
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
My wipers are due for a change and need to get some in the next few days.
Now at the moment when they reach there distance and change to come back there is a thud....
after a while it tends to get on your wick.
So before i buy, anyone have the same issue and what ones did you get.
or if you dont have the isseu, what one do you have.
Or is it common and i just have to deal with it
Cheers...
Turning the radio up help
Post #405264 18th Sep 2016 7:15pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
i use bosch 808 they are the best i find ,i used some cheaper ones once and had the same problem as you but not with the bosch ones
Post #405265 18th Sep 2016 7:18pm
Rosco
There is a few threads on this subject, I changed to Bosch Aero blades and cured all thuds Thumbs Up
Post #405266 18th Sep 2016 7:18pm
Weegie
Wiper blades worn out. You need new ones. Had the same problem and fitted Bosch 808s. Problem solved. There are some threads on the subject with others fitting different blades. John
GAP iiD BT-Sold
Post #405268 18th Sep 2016 7:20pm
Sleeper
cool, found some and they are in the basket, but need numberplate bulbs, started a different thread to seporate the subjects
Cheersss....
Post #405272 18th Sep 2016 7:39pm
comports
the real reason for the thud is actually because they need adjusting.
They should be at a certain angle (but I can't remember what at the moment) - if you are not changing the blades then you can alter the angle that the existing blade meets the glass but loosening the nut, twisting the blade a little and re tighten the nut.
its s little more difficult than I explained (but not a lot) but certainly something that you can fix Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #405448 19th Sep 2016 7:32pm
this is what Ash is referring to,
Post #405458 19th Sep 2016 8:11pm
comports
Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #405509 20th Sep 2016 7:54am
