![]() | Home > LPG > LPG Self Service Help |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Hi there,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8491 ![]() ![]() ![]() |
What has getting hot done to it...??? Pete
Hey Pete-I strike again! |
You will need to take the vaporiser off to change the diaphragm, no need to isolate anything, with the LPG system turned off all that will escape is the gas in the pipe... it's heavier than air so be carefull if you do it indoors...
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
The car broke down on the girls and they got recovered- details are hazy
Yeah Spock- I've chewed through a few £300 BRC vaporisers on boats!!
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Since mine was leaking, there was no gas between the shut-off solenoid and the filter. The passages are small, I can't imagine it would be much more than the filter. You'll be emptying the filter and the pipe leading to it. Having said that, I would say that if there's no leak, leave it alone. |
