![]() | Home > Technical (L322) > 50 euros a litre for oil?! |
Ha! my rear diff oil is $170 per litre , but it might help if you tell us what FullFat you have and what oil you require .
MarkWillenbrock Member Since: 25 Aug 2016 Location: Fes Posts: 6 ![]() ![]() |
It's a 2004 bmw engined petrol 4.4 litre. Originally US market but somehow arrived in Morocco.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
its in the wiki at the top of the page......but here you go..... |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
ebay
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2663 ![]() ![]() |
I buy it at around $90/L from an independent supplier. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
Note that the table incorrectly identifies Dexron III as a suitable alternative to LT71141. I’ve seen, on several occasions, what happens when you put Dexron in a 5HP24. The only ZF approved fluids for the 5HP24 transmission are (part-synthetic) Mobil ATF LT71141 and (fully-synthetic) ZF Lifeguard Fluid 5 & Pentosin ATF 1. Here in the UK only the Mobil fluid is easily available at anything like an acceptable price. Elsewhere in the world the other two fluids may be easier to get hold of.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I must admit I was surprised to see dextron 3 listed.... |
E-diff + WA = humped ![]() Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
Will Karcraft send it? |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
You might want to read this thread. One of these other brands will work fine and may be cheaper. I can get pentosin or Febi for about $10/litre delivered.
I'm carrying some febi bilstein as a reserve, but I don't think it's compatible. |
It will say on the back if it is LT 71411 equivalent. I've been running the Febi equivalent. I will be changing to the Pentosin shortly because it is fully synthetic and costs the same here. |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Phil,
here you go Ed |
