Home > Technical (L322) > 50 euros a litre for oil?!
MarkWillenbrock
Morocco
Having been ripped off by my local stealer for automatic transmission fluid, I'm wondering if anyone has a definitive list of the oil specs for the L322?
Mine is a 4.4 petrol.
I know oil is important, I know it's not all the same, but I'd prefer to buy it from an oil company!
Post #403873 7th Sep 2016 2:29pm
Ha! my rear diff oil is $170 per litre , but it might help if you tell us what FullFat you have and what oil you require .
p,s a full list of lubricants and fluids id available in the Wiki . 2008 MY Supercharged
Post #403875 7th Sep 2016 2:45pm
MarkWillenbrock
Morocco
It's a 2004 bmw engined petrol 4.4 litre. Originally US market but somehow arrived in Morocco....
Post #403892 7th Sep 2016 3:43pm
its in the wiki at the top of the page......but here you go..... Thumbs Up
http://www.fullfatrr.com/wiki/Recommended_Lubricants There is nothing that can't be fixed with a hammer😜😜
Post #403901 7th Sep 2016 4:16pm
Clivefog
ebay
http://www.ebay.co.uk/itm/5L-Mobil-Esso-LT...SwMNxXbQzE
Post #403941 7th Sep 2016 8:29pm
GraemeS
Australia
I buy it at around $90/L from an independent supplier.
Post #403955 7th Sep 2016 9:53pm
RRPhil
Note that the table incorrectly identifies Dexron III as a suitable alternative to LT71141. I’ve seen, on several occasions, what happens when you put Dexron in a 5HP24.
The only ZF approved fluids for the 5HP24 transmission are (part-synthetic) Mobil ATF LT71141 and (fully-synthetic) ZF Lifeguard Fluid 5 & Pentosin ATF 1. Here in the UK only the Mobil fluid is easily available at anything like an acceptable price. Elsewhere in the world the other two fluids may be easier to get hold of.
Phil
Post #403964 7th Sep 2016 11:19pm
MarkWillenbrock
Morocco
I must admit I was surprised to see dextron 3 listed....
Post #403970 8th Sep 2016 1:15am
E-diff + WA = humped Big Cry 2008 MY Supercharged
Post #403972 8th Sep 2016 1:33am
GraemeS
Australia
Will Karcraft send it?
Post #404041 8th Sep 2016 12:17pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
You might want to read this thread. One of these other brands will work fine and may be cheaper. I can get pentosin or Febi for about $10/litre delivered.
http://www.fullfatrr.com/forum/topic38595.html
Post #404054 8th Sep 2016 3:17pm
MarkWillenbrock
Morocco
I'm carrying some febi bilstein as a reserve, but I don't think it's compatible.
Post #404133 9th Sep 2016 7:12am
doclees
It will say on the back if it is LT 71411 equivalent. I've been running the Febi equivalent. I will be changing to the Pentosin shortly because it is fully synthetic and costs the same here.
Post #404167 9th Sep 2016 2:13pm
sako243
Phil,
I seem to remember I found ZF Lifeguard on Island4x4 for about £12/l. Might be remembering incorrectly but it was for my 6hp26 and people commented it was a damn sight cheaper than anywhere else. Ed
Post #404234 9th Sep 2016 7:38pm
sako243
here you go Ed
Post #404235 9th Sep 2016 7:39pm
