Home > Maintenance & Mods (L322) > Febi gearbox oil
Danwilderspin
Febi gearbox oil
Hi all is this ok to use in the 4.4 m62 v8 gearbox
febi bilstein 29738 Automatic Transmission Fluid ATF (Yellow) 5 Litres https://www.amazon.co.uk/dp/B006DHRUM0/ref...3xb7VESVP1
It says it's yellow and is lt71141
Thanks
Post #405396 19th Sep 2016 2:19pm
RRPhil
That fluid may be identical to the ZF specification fluid, or it may not. We have no way of knowing. You’ll save around £20 compared with using the official 5HP24 fluid – Mobil ATF LT71141. A replacement transmission costs around £2000. It’s your choice.
Phil
Post #405545 20th Sep 2016 12:31pm
