Home > Maintenance & Mods (L322) > Are all aircon regasses the same
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
noticed today the aircon in the FFRR is not even cool, maybe slightly cooler than outside, but it certainly doesnt cool the cabin at all. Are all regas services the same? Ive seen prices vary from £30 to £80+ so unsure of where to go for it?
Somewhere like kwik fit and deal with the spotty school leaver, or an aircon specialist who may charge twice the price?
Any advice greatly appreciated guys, I'm on the Herts/Essex border if that helps
Post #403065 2nd Sep 2016 5:03pm
Clivefog
Spotty "fitter" will do a fair job as the machine does it all as long as the correct vehicle is entered.
Should you have a bigger problem then a expert will be the way to go.
If you don't think there are any other problems i.e. no funny yellow patches or wet looking joints on the A/C pipes a simple refill should do the job, provided it has been cooling well up to now.
Post #403066 2nd Sep 2016 5:20pm
Dolphinboy
Halfords were recently doing a £30 recharge while u wait in the car park. No appointment and the whole thing took just 10 mins. Beats all the other aircon pros who said I had to book, leave it with them for a couple of hours and wanted £50!
Well done halfords I say! Bow down Thumbs Up (and that was just a shop, not the garage type of halfords)
Post #403070 2nd Sep 2016 5:45pm
Halfords Autocentrres also do a complete EMPTY/CLEAN/RECHARGE service for about £45 using the very latest equipment.
Post #403073 2nd Sep 2016 5:57pm
As said depends on why the level of gas has gone down to start with. As its a sealed system it shouldn't drop, but they do, and anyone with a proper machine will try to draw a vacuum first. This will show up any leaks. If it is all good then this is where a cheapo refil is fine.
Next stage would be to inject an UV dye into the system and put it under positive pressure, this will show where the leaks are. You are then at the mercy of whatever component you need to seal the system up again. At this point a more specialised centre will be best, do you really want the spotty 17yo at halfords trying to diagnose a condenser with a hole or a duff dryer.....
I would let the chap at halfords have a go, if it draws a vacuum, all good, if not then Iirc they won't charge you and you can see a specialist. There is nothing that can't be fixed with a hammer😜😜
Post #403074 2nd Sep 2016 6:00pm
^+1 for above Bow down NMJ
Post #403139 3rd Sep 2016 11:17am
Tuts
I was told by my local mobile air con guy that the early BMW rangies had a very small capacity of refrigerant which meant that they need re-gassing more often than the later ones which had two separate systems ( one for the back seats?)
Even with a good vacuum mine seems to lose gas over time with no obvious leaks ? I have mine redone every 18 months 2003 Vogue 4.4 V8 Java Black
Post #403700 6th Sep 2016 6:17pm
HGv driver
Wales
had mine done at halfords autocentre in april its still ice cold so it was 45quid well spent ps its on 24/7 winter spring autum summer
Post #403703 6th Sep 2016 6:31pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I wouldn't trust a 10 min air con regas, my regas machine takes 15 minutes to test the system alone, and many regas system I have used takes 15 mins or longer doing a leak test 10 mins may have just been connect the system and filled with a small amount to get you working again
Post #408209 7th Oct 2016 9:19pm
Had SWMBOs skoda done at kwikkies. took about 40 mins i think, the machine did a full purge of the system, then a leak test before filling it with gas. All automatic plug and play for the guys there.
was pretty cold after, though the car has now gone, it was another job ticked off the list..... There is nothing that can't be fixed with a hammer😜😜
Post #408297 8th Oct 2016 2:40pm
Weegie
AFAIK a leak test is compulsory before a re-gas. It is a legal requirement here in France and i thought throughout Europe. It makes sense as there seems little point in puting environmentally dangerous gases into a leaking system.. John
GAP iiD BT-Sold
Post #408303 8th Oct 2016 3:10pm
Lukie
in the UK it is illegal to knowing allow R341a (or any a/c gas) to escape into the atmosphere
everyone doing any work on a aircon system should be F gas registered, but alot are not
A/C recon should take 30+ at the very least
Post #408377 8th Oct 2016 11:31pm
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
Thumbs Up Thumbs Up Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #408379 8th Oct 2016 11:52pm
miggit
Rolling Eyes Don't think that's right.. I was told they use a lot of gas...
When I had mine done last it over 10 minutes to evacuate the system before filling, the whole thing took just over 30 minutes to do... And then it naffed up again 3 months later Evil or Very Mad
In the end I got a can of A/C leak sealer and a can of top up gas from halfauds and did it myself, I caused no end of objections on here when I did... being accused of bodging the whole thing... Whistle still working 14 months later ! Whistle
http://www.fullfatrr.com/forum/topic33288.html Yesterday I couldn't spell Engineer... Today I are one!
Post #408381 9th Oct 2016 12:10am
mrblonde
Cheers guys, due to the recent weather change a re-gas has been bumped down the 'to do list' by a new number 1 priority, heated steering wheel not working (well, lighting up for a split second the going off again).
Post #409129 13th Oct 2016 11:49am
