![]() | Home > Maintenance & Mods (L322) > Are all aircon regasses the same |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Spotty "fitter" will do a fair job as the machine does it all as long as the correct vehicle is entered.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
Halfords were recently doing a £30 recharge while u wait in the car park. No appointment and the whole thing took just 10 mins. Beats all the other aircon pros who said I had to book, leave it with them for a couple of hours and wanted £50!
Halfords Autocentrres also do a complete EMPTY/CLEAN/RECHARGE service for about £45 using the very latest equipment. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
As said depends on why the level of gas has gone down to start with. As its a sealed system it shouldn't drop, but they do, and anyone with a proper machine will try to draw a vacuum first. This will show up any leaks. If it is all good then this is where a cheapo refil is fine.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
^+1 for above |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
I was told by my local mobile air con guy that the early BMW rangies had a very small capacity of refrigerant which meant that they need re-gassing more often than the later ones which had two separate systems ( one for the back seats?)
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 ![]() ![]() |
had mine done at halfords autocentre in april its still ice cold so it was 45quid well spent ps its on 24/7 winter spring autum summer |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
I wouldn't trust a 10 min air con regas, my regas machine takes 15 minutes to test the system alone, and many regas system I have used takes 15 mins or longer doing a leak test 10 mins may have just been connect the system and filled with a small amount to get you working again |
Had SWMBOs skoda done at kwikkies. took about 40 mins i think, the machine did a full purge of the system, then a leak test before filling it with gas. All automatic plug and play for the guys there.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
AFAIK a leak test is compulsory before a re-gas. It is a legal requirement here in France and i thought throughout Europe. It makes sense as there seems little point in puting environmentally dangerous gases into a leaking system.. John
in the UK it is illegal to knowing allow R341a (or any a/c gas) to escape into the atmosphere
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
![]() ![]() ![]() 2017 Range Rover Autobiography 5.0 V8 2018 JCW Mini Cooper 2018 Skoda VRS |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
![]() When I had mine done last it over 10 minutes to evacuate the system before filling, the whole thing took just over 30 minutes to do... And then it naffed up again 3 months later ![]() In the end I got a can of A/C leak sealer and a can of top up gas from halfauds and did it myself, I caused no end of objections on here when I did... being accused of bodging the whole thing... ![]() ![]() http://www.fullfatrr.com/forum/topic33288.html Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 732 ![]() ![]() ![]() |
Cheers guys, due to the recent weather change a re-gas has been bumped down the 'to do list' by a new number 1 priority, heated steering wheel not working (well, lighting up for a split second the going off again). |
