![]() | Home > Technical (L405) > Heat in the front |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1458 ![]() ![]() ![]() |
Sounds strange, mine gets warm but not uncomfortable? |
RR5.0SC Member Since: 22 May 2016 Location: Hertfordshire Posts: 24 ![]() ![]() |
It was properly warm, couldn't rest my leg against it.
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
I'd be asking LR to check it over. I've only had the 3.0 TDi versions but never had that issue. |
Mine only gets really hot when the rear heating is up high but i have the exec seating so not sure if that helps.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
You should get it checked by your dealer - mine is just normal |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3778 ![]() ![]() |
Probably Low gearbox oil, or a heat shield is missing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
