Home > Technical (L405) > Heat in the front
RR5.0SC
Heat in the front
Did my first run today other than local running about and the heat from the transition tunnel was quite warm against my leg. Almost uncomfortable.
I've had a 3.0 and 4.4 405 and never noticed this before.
Would appreciate your thoughts.
Thanks.
Post #401203 19th Aug 2016 8:03pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Sounds strange, mine gets warm but not uncomfortable?
Post #401210 19th Aug 2016 8:29pm
RR5.0SC
It was properly warm, couldn't rest my leg against it.
Switched off the cold box and cooled drivers seat and made sure rear vents were not in heating and made no difference.
Was like being in a tvr again!
Post #401211 19th Aug 2016 8:33pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
I'd be asking LR to check it over. I've only had the 3.0 TDi versions but never had that issue.
Post #401212 19th Aug 2016 8:43pm
DrF
Mine only gets really hot when the rear heating is up high but i have the exec seating so not sure if that helps.
Best to get checked out matey
DrF
Post #401219 19th Aug 2016 9:06pm
You should get it checked by your dealer - mine is just normal Smile All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #401242 19th Aug 2016 11:12pm
Vogue
Probably Low gearbox oil, or a heat shield is missing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #401273 20th Aug 2016 8:18am
