Home > Maintenance & Mods (L322) > Grinding brakes
Sandyt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Grinding brakes
Afternoon all right I have grinding brakes but only on hard braking from speed there is no pull,vibration or shudder through the steering column just a bloody awful noise now my thinking is new discs and pads needed as this might be caused by a slight lip on the disc and the pads mayor may not be brembo or am I missing something that could be causing this din - on slow braking i.e. in traffic all is relatively quiet and smooth but when nor braking a squeal - pads and discs me thinks
Post #284652 6th Oct 2014 4:47pm
abs66
I have EXACTLY the same symptoms you had 2 years ago.
Did you ever get to the bottom of it?
Cheers
Pete
Post #400880 17th Aug 2016 6:03pm
Sandyt
Yes resolved this with new discs and pads put genuine on and never had a problem since the ones that were on were aftermarket put on by previous owner
Post #400927 17th Aug 2016 10:06pm
abs66
Thanks Sandyt, that is good to know.
It confirms what others have suggested.
Do mind letting me know how much that cost please?
Cheers
Pete
Post #400934 17th Aug 2016 10:42pm
Sandyt
It depends which brakes you have mine are Brembo got everything from Dan at Duckworths give him a ring he will give you a price or PM him on here he gets back really quick Thumbs Up
Post #400944 18th Aug 2016 5:01am
abs66
Thanks for the reply.
I'm thinking they probably are Brembos, I'm sure they went back to them on this model year. I didn't notice any logo on the calipers but to be honest I was concentrating on the discs and pads. I will have a closer look later.
Pete
Post #401020 18th Aug 2016 3:29pm
