![]() | Home > Maintenance & Mods (L322) > Grinding brakes |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Afternoon all right I have grinding brakes but only on hard braking from speed there is no pull,vibration or shudder through the steering column just a bloody awful noise now my thinking is new discs and pads needed as this might be caused by a slight lip on the disc and the pads mayor may not be brembo or am I missing something that could be causing this din - on slow braking i.e. in traffic all is relatively quiet and smooth but when nor braking a squeal - pads and discs me thinks |
abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93 ![]() ![]() |
I have EXACTLY the same symptoms you had 2 years ago.
Yes resolved this with new discs and pads put genuine on and never had a problem since the ones that were on were aftermarket put on by previous owner |
It depends which brakes you have mine are Brembo got everything from Dan at Duckworths give him a ring he will give you a price or PM him on here he gets back really quick |
Thanks for the reply.
