![]() | Home > Technical (L322) > Fuel type |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
In the uk, our 'regular' fuel, is 94 octane. We can get a premium 98 fuel here too.
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 ![]() ![]() ![]() |
Wow! You have that high of an octane? Our max, at least where I live, is 91. I wonder if I could use Xylene to raise my octane. Xylene is pretty cheap. |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
We used to have BP Ultimate 102 at our local station but haven't seen it for a couple of years. Think the highest RON available here now is Shell V power 99 |
Does UK gasoline have any ethanol in it? |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Don't confuse US octane ratings with European ratings, they are measured differently.
Thanks for all that interesting information. What do you think about running non ethanol 89 Octane? I get better mpg with it in all my other vehicles. Thank you |
that explains to me! I thought it had to be similar. |
It's certainly worth trying if you find it's better than other types in your other motors.
You obviously know your stuff. How about this? Can't you raise the octane of gasoline with the common chemical xylol? Isn't that what petroleum companies use to raise octane? I read that somewhere. What if you raised the octane of your fuel using xylol? Is there a formula for that just curious. Not necessarily going to try it unless someone tells me it's common practice. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1558 ![]() ![]() |
I think most of the world uses RON.
I know a bit after researching info many years ago when running a high performance jap import that wouldn't run on anything else but high octane fuel but I'm certainly no expert.
Yes I prefer to run non ethanol. My vehicles get better mpg but of course the non ethanol is slightly more expensive so I don't know if it evens out or not. Just thought maybe if I could not use 89 reliably, maybe I could boost it sufficiently and cheaply. Next time I need fuel I'll tank up with the non ethanol and see how it goes. |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 389 ![]() ![]() |
I am in Sun Valley. I have a 2011 SC and only use 91 octane Non-ethanol. Its $3.29 here but car runs great. |
I would only use the 91 non ethanol not the 89 but that me. |
