Home > Maintenance & Mods (L322) > Roof Rack |
Unless you're 9 feet tall you will need a step ladder to get up to it |
28th Nov 2010 3:55pm |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 |
Sad as it may seem it will only get very minor use.
28th Nov 2010 3:58pm |
Do you need a full on roof rack or will roof bars do?
28th Nov 2010 4:02pm |
I think I want the full Roof rack look.
28th Nov 2010 4:16pm |
Roof rails cause extra slipstream drag and higher fuel consumption plus a lot of wind noise |
28th Nov 2010 4:24pm |
I have roof rails, they are fixed then you just clip the bars into them when needed. The problem with a full rack is the noise and mpg loss. |
28th Nov 2010 4:25pm |
What are we guessing on MPG loss?
28th Nov 2010 4:35pm |
Rails are fitted lengthways so have no effect on aerodynamics as the leading edge is so small it keeps Frontal Pressure to a minimum also as they are one solid piece you get no Flow Detachment, The problem comes when you fit crossbars as these cause significant turbulence, this is what causes the noise. As a result of the turbulence and frontal pressure this increases your Drag Coefficient, this is what reduces your MPG. |
28th Nov 2010 4:59pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
as an occasional user of roofrack i went for the thule option. on and off within minutes, also have a choice on distance between. |
28th Nov 2010 5:28pm |
David have you any pictures? 15MY SDV8 Vogue SE |
28th Nov 2010 6:29pm |
Jem, yes indeed somewhere on this forum - a picture taken last winter in the alps.
28th Nov 2010 8:03pm |
Looks good David. Still think I want the full Rack look. Will take the plunge. What's the worst that can happen. Apart from a kicking from Mrs Jem. 15MY SDV8 Vogue SE |
28th Nov 2010 8:13pm |
For the amount of use it i'm happy. Fortunate thing was i already had the attachments, ski rack load stops etc etc.
28th Nov 2010 8:20pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2036 |
Thule for me as well
28th Nov 2010 8:29pm |
